Futaba FP-8U radios, how good were they.
Reply
Old 08-31-2011, 07:16 AM
karolh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Futaba FP-8U radios, how good were they.
The Futaba FP-8U series radios have been discontinued for some time now, however numerous variants of them are still in use and performing flawlessly. I am aware that stacked against the current whizz bang radios they would most likely pale in comparison, but in their time just how good were they?
Karol
karolh is offline
Old 08-31-2011, 09:16 PM
Dave McDonald
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Futaba FP-8U radios, how good were they.
The old 8U radios would only pale in comparison to some of the upper end radios of today. It's still superior to any of Futaba's current transmitters from the 7C on down. Even the old 9C didn't offer much more than the 8U Super. The 8U is definitely superior to my Spektrum DX7. Not sure about the DX8 because I haven't seen one yet. You'll need to get into a JR 9303 or higher to begin getting more than an 8U offers. The only radio that Hitec offers that's superior to the 8U is the Aurora 9. I'm not familiar enough with Airtronics stuff to give an opinion, although I suspect the top of the line radio is comparable to the Aurora 9.
I bought two used 8U radios over 15 years ago. A few months ago I sold both of them to a local guy and his son who are still flying them with the FR Sky 2.4 modules and receivers. They are now on their 3rd set of batteries, and they both still work perfectly.
Dave McDonald is offline
Old 09-01-2011, 01:09 AM
A.T.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: karolh The Futaba FP-8U series radios have been discontinued for some time now, however numerous variants of them are still in use and performing flawlessly. I am aware that stacked against the current whizz bang radios they would most likely pale in comparison, but in their time just how good were they? Karol
Post #2 +1, but easily upgraded/swappedto/from2.4Ghz.
. Also be aware 8U is aged and even if seldom used, the wires attached to moving parts,
even when via a small circuit board mounted at the base of stick, the plastic hardens causing wire fatigueto the point of breaking. see example jpg of a FF8 Broken Gimbal Wire
Periodically checksall wiring, especially for Black Wire Corrosion.
. Following may also assist:
Futaba - 8U Radio System FAQ
Futaba - Compatibility - Interchange of Modules between 8U, 9C, 9Z , 12Z& 14MZ
Futaba - Hitec Modules are compatible
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline
Old 09-05-2011, 07:10 PM
John Sohm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I still have mine. Actually that's not completely true as I gave it to my son. Never had a problem with that radio, worked from day one and is still going strong.
John Sohm is offline
Old 09-05-2011, 07:23 PM
karolh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bought mine in 1997 and it's still going strong but now on 2.4. Had a couple things done to it over the years, like having the module pins resoldered, replacing a broken dual rate toggle switch and a succesful DIY repair of a broken gimbal stop on the rudder axis.
Karol
karolh is offline
Old 09-05-2011, 07:24 PM
BuschBarber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had an 8AUPS. I had a problem shortly after I started using the radio. I suddenly had no range. I tried a different RF Module, but it was obviously a Tx problem. I opened the case and found that the circuit board where the antenna attached had a crack across the antenna circuit. A friend of mine, who worked for a company that made radios for the military, was able to solder Buss wire and repair the circuit. I never had another problem with the radio and eventually had Futaba replace the board with a new one, just to be safe. Never a problem besides that one.
BuschBarber is offline
Old 09-09-2011, 05:45 AM
ronwc
ronwc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Still using mine on channel 32 as my primary radio - never a problem or crash. I keep 16 planes in memory all the time. I hear there is some new radios out, but don't want to rush into anything, maybe in a few years I will change.
ronwc is offline
Old 09-09-2011, 12:24 PM
rmh
rmh's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
wow - I am surprised when I see people are still using these radios
-In today's world of electronics -they are relatively ancient - but if interferrence by others is not a problem- then no real problems exist.
I never liked em - too hard to setup (relative to my JR 10 series stuff ) but others I fly with really liked em.
rmh is offline
Old 09-12-2011, 08:13 PM
chuckk2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have 2 of the 8U's (bought used) Both work quite nicely, and are compatible with the Spectrum 2.4G TX module.
The major difference between them and the 9C was that the 9C has expanded Helicopter related features.
chuckk2 is offline
Old 09-19-2011, 08:52 PM
ptgarcia
ptgarcia's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had an 8uaps and loved it. It took a little work to figure out the programming (the book by Don Edberg is a huge help) but once you get it down its great. Mine was stolen when my truck was broken into 8 or 9 years ago (replaced with 9C) otherwise I'd probably still have it today.
ptgarcia is offline
Reply
Display Modes
