Will this cause interference?
Reply
Old 08-20-2003, 10:18 PM
canesugarrules
canesugarrules's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Will this cause interference?
I am building a Wattage Crazy Max (electric). It is a fairly tight fit in the fuselage, and the elevator and rudder servos are touching (HS-55). Will this cause any interference?
canesugarrules is offline
Old 08-21-2003, 03:52 AM
Lynx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not very likley, as long as the control arms can't hit each other.
Lynx is offline
Old 08-21-2003, 01:45 PM
FLYBOY
FLYBOY's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have done that quite a bit. You shouldn't have a problem.
FLYBOY is offline
Old 08-21-2003, 08:11 PM
canesugarrules
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks. Only the cases are touching. I'm going to range test anyway.
Old 08-22-2003, 01:24 AM
jchuston
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I own a Crazy Max (bought it in February of this year) and I think that this is standard for the servos to touch (at least for the Rudder/Elevator combination of servos...)
I am not using 55's, I am using 81's, but they will be fine...just be careful with how you locate the wing in the wing saddle, and make sure that you do a little sanding around the sharp edges of the saddle after you cut it down to size...I didn't have this problem, but I have heard of a couple of people losing their fuse from the wing because that sharp-edges plastic cut through the rubberbands that they were holding their wings on with...also, even though the plans call for 2 rubberbands on the wing...just use 4...better safe than sorry...
-John
jchuston is offline
Old 08-24-2003, 05:09 PM
canesugarrules
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
