Power for gas RX setup ?
Iam building a P-51 with possible gas engine. The servos I am looking to use can use 6V power, and there will be 6-8 servos, possible S3004 Futabas, and a Spektrum RX. If I use a 2S Lipo, what C and mah size would I need and what would I need to go between the pack and the RX. If I go gas, the ignition needs power too, so would I use a separate pack, or share one pack?
CO
RE: Power for gas RX setup ?
ORIGINAL: acdii
Ihave been using 2S LiFe batteries (A123, Lithium Iron Phosphate), the voltage is 6.6 volts, I power RX's right through the switch with no regulator. For Spark ignition modules I have been using the Wike RC battery eliminator filter, which allows me to power the ignition module from the same battery pack, and is filtered for RFI.. I love these things, they work great!
So something like this? http://www3.towerhobbies.com/cgi-bin...?&I=LXYAS9&P=0
Three output leads, and a balance jack. SO one of these can be used, one jack into the RX, one for the ignition, and the third as the charging jack? My TT Charger supports all battery types and charges my Lipo with a DEANS like this one has. It's a 2100 10C, how many flights could I expect between charges when used for both?
ORIGINAL: acdii
ORIGINAL: acdii Iam building a P-51 with possible gas engine. The servos I am looking to use can use 6V power, and there will be 6-8 servos, possible S3004 Futabas, and a Spektrum RX. If I use a 2S Lipo, what C and mah size would I need and what would I need to go between the pack and the RX. If I go gas, the ignition needs power too, so would I use a separate pack, or share one pack?
(Being the reason why the discontinued S148 and S3001 servos were re-introduced for use with small glow powered Heli etc.)
S148 & S3001 vs. S3003 & S3004 refers.
As an aside, there would be few models utilising a petrol engine which would be small/light enough
to ensure the gears on any of those servos would not strip in flight or hard landings.
Suggest you consider larger servos with thicker/stronger gears or MG servos.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
1 Post
ORIGINAL: acdii
a 2100mA.hr LiFeSource pack running both Ignition and Rx will give you around 5save flights if using 9std analogueservo's and a voltage drop diode between the battery and the ignition.
I'd up the capacity to 3000mA.hr if using digital servo's
Thanks. Ithink Inarrowed it down to 6 analog servos, one retract servo and a pair of Eflite electric retracts. Ithink I will go with a separate pack for the ignition just to be on the safe side.
You certainly could, but I run 50CC planes with a lot of servos (no retracts) with a single A123 with drop down.
I'd go with a 2300 rx A123 and an 1100mah A123 or 4 cell nicad for the ignition if you're going to split battery duties.
I get mine from WrongWayRC.com
ORIGINAL: acdii
Thanks. I think I narrowed it down to 6 analog servos, one retract servo and a pair of Eflite electric retracts. I think I will go with a separate pack for the ignition just to be on the safe side.
Just a heads up. I think they are really designed for electric, low vibration situations.
