7955tg -jittering-should I be concerned?
My Feedback: (212)
NC
Just put two HS-7955TG servos on the elevators of my 35% Extra and they must be nervous because they have some amount of noise and jittering when at neutral. They operate fine through the entire range of motion and are responding perfect,they just act like they are continuously trying to find center.
I understand that this is not uncommon,my only question is are they safe to fly?
My Feedback: (90)
RE: 7955tg -jittering-should I be concerned?
If the jittering disappears when you stand the plane up (i.e., to cancel the weight of the elevators on the servos), then it probably is safe to use them. Are these servos in good shape otherwise, and the dead-bend is set to the minimal?
My Feedback: (212)
NC
yes it will almost go away when I stand the plane on its nose. I may have used the wrong word "jittering". it is more like a buzzing noise.
GA
ORIGINAL: flyerdave
ORIGINAL: flyerdave
yes it will almost go away when I stand the plane on its nose. I may have used the wrong word ''jittering''. it is more like a buzzing noise.
My Feedback: (16)
NY
SIR,I just moved to Rochester from Albany.What club do you belong to & what part of the area is your club field? I now live near " 12 corners"
Thanks, Bill Rogers [email protected]
ORIGINAL: RCplanman
SIR,I just moved to Rochester from Albany.What club do you belong to & what part of the area is your club field? I now live near '' 12 corners''
This is a public park, but we maintain the runways and pit area. All you need is an AMA Licence to fly there, so you do not need to belong to a club, however, non of the amenities would be there if it were not for our club, including the mowing of the runways and pit area.
We also have a private club field, off Ridge Rd West, which we use all year round. Northampton Park is only open from May until the first snow.
Our club web site is www.rccr1957.com.
