Sanwa RD6000 Problem
Reply
Old 08-24-2003, 02:54 PM
solentsurfer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Sanwa RD6000 Problem
I recently purchased a new battery for my RD6000. Not realising that the polarity was wrong on the battery, I momentarily switched on!!. Switching off, I changed the leads round in the plug and switched on again. At first all appeared fine but I now have an intermittant problem with the transmitter not working. Switch off and on and it will work again.
The question is, could the polarity problem cause such a poblem? I would have thought any damage would be permanent, not intermittant.
Any thoughts would b much appreciated before I source another transmitter.
solentsurfer is offline
Old 08-24-2003, 03:22 PM
Lynx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check all your wireing you may have an intermitant short from a burnt wire.
Lynx is offline
Old 08-24-2003, 04:33 PM
solentsurfer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Lynx, I took the back off the transmitter and checked best I could.. it would appear as though a dodgy connection is the problem.. can't see anything obvious though.
Old 08-25-2003, 10:39 PM
Lynx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Intermitant problems are always difficult to find.
Lynx is offline
Old 08-27-2003, 06:16 AM
CrashingDutchman
CrashingDutchman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
I bought the same transmitter you are talking about on eBay, but it came without battery.
Any idea what connector I should get for this radio?
Can anyone say what the positive pin is on this radio?
Regards,
Jan-Dirk
CrashingDutchman is offline
Old 08-27-2003, 06:47 AM
solentsurfer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Positive pin is the bottom one (on mine at least, assume they will all be the same) If you want to be sure, buy a battery specifically for it - branded Sanyo (not Sanwa). Any connector will do as long as the polarity is right. Some connectors have a locating tab down the side, just trim that off and shamfer the corners a little to fit the connector slot in your transmitter.
Old 01-27-2004, 08:53 PM
W_I_Z
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Sanwa RD6000 Problem
HI, i just got myself a second hand Sanwa rd6000 sport radio, i dont know much but am told that it is quite adequate for flying my Sceadu 50, the problem i have is that i need a manual for it so that i can try to understand the setup, does any1 know where there is 1 online or can any1 tell me how 2 set it up???????????????????????/
W_I_Z is offline
Old 01-27-2004, 09:15 PM
CP140
CP140's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Go to airtronics.net You'll be able to download a manual from there.
CP140 is offline
Old 01-27-2004, 09:17 PM
bigbri
My Feedback: (287)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yup....did the same thing myself......Did you get the puff of smoke ??? I did. My radio will not trancmit a signal at all. I took it apart and cannot find anything that looks charred or melted, I didn't even try to fix it. Chalked it up to experience and bought a new one. W_I_Z PM me your address and you can have my manual for the cost of shipping....2 or 3 bucks at most
B-
bigbri is offline
Old 01-28-2004, 07:50 AM
slovac
slovac's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
bigbri ...
I had the same experience (little puff of smoke) ...
I took the same route as you and went out and bought another radio, but after a couple of weeks I got curious about the origin of the smoke and took it to my LHS ... they sent the radio away for repairs. Not to the agents, but to some tech that fixes electronic equipment for them. I got the radio back within a week and was charged the equivalent of about $15 (at current exchange rates).
I was told that reversing the polarity blew a capacitor ... nothing serious, and easy to replace.
slovac is offline
Old 01-28-2004, 08:19 PM
bigbri
My Feedback: (287)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WOW thats great info.....I still have the TX....Just mught have to send it out for repair. I replaced it with a Fut 6xas, but got to admit the
RD 6000 has better features
Thanks for the tip
Brian
bigbri is offline
Old 01-28-2004, 08:40 PM
W_I_Z
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
cheers for that, i found the manual online and now i understand it. All i gotta do now is transfer my gear from my shuttle to my super sexy new Sceadu 50 which arrived today
W_I_Z is offline
Old 02-10-2004, 11:39 AM
wingdragon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dear all,
I just bought a used RD6000 sport system and having some question, please help!
1. does the sytem still works if the pwer lever drop below 9.2V as my system seems to not responding at all, wondering if the radio is broken or just a low voltage problem.
2. i dun have the factory charger, want to know what should be the voltage amp of the charger if i bought a aftermarket one.
Many thanks!
My email is Stevenkwok_hk@hotmail.com
wingdragon is offline
Old 02-10-2004, 11:42 AM
wingdragon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dear all,
forget to ask this - as i use the system to fly electric plane, which socket should i use at the RX for the speed control. As i found that 7/B is for battery but 4 is for Throttle, I am now very confused! []
Old 02-10-2004, 12:10 PM
hattend
My Feedback: (20)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Plug the ESC into the Throttle and the battery into 7/B
Don
ORIGINAL: wingdragon
Dear all,
hattend is offline
