servo jitter on range check please help
Reply
Old 08-25-2003, 12:42 PM
Dave763
Dave763's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default servo jitter on range check please help
I have a 40 size cap that the servos jump around like crazy on a range check. The problem is still there after switching the reciever and transmitter. I have tried bypassing the switch, and using different batteries. Is it possible that a servo could do this?
Dave763 is offline
Old 08-25-2003, 01:22 PM
kenken
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You have a problem. you have to go by the book to find the trouble. Check the position of the RX in relation to the battery, the type of pushrods (metal), their proximity to the antenna. The length of the wires(if you have servos at the back of the plane). Any metal to metal contact (motor throttle), run your antenna outside the fuselage. Could be servo trouble(check that they operate easily by hand, no restriction on movement is allowed, sometimes the rods interfere with one another or the hinges do not allow full travel. Keep trying, you will find the problem. If you dont, do not fly!!!
Jerry
kenken is offline
Old 08-25-2003, 03:51 PM
vinnie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Are you using 6 volt battery packs?
Does the jitter stop if you extend the trans antenna slightly?
vinnie is offline
