8FG Super Impossible
My Feedback: (25)
Is it just me or is the new Futaba 8FG Super just about the most complicated radio system ever devised. I've been messing with it and the manual for nearly an hour and gotten no place. On top of that the method for scrolling seems imprecise and often doesn't schroll. I have been using a 9C for years and right now I'm thinking about just selling this thing.
My Feedback: (19)
RE: 8FG Super Impossible
ORIGINAL: splais
Overall, when you get use to the programming it isn't difficult at all. I do wish it had a separate return to top button so you wouldn't have to return to the top of a page to go back to the previous function or page. That alone would make programming much faster.
Part of the problem with the 8FG it the depth of the programming functions. When you have the ability to assign just about any button, switch or stick to any channel or function, it takes a lot of steps to get there. That combined with just one method of data entry makes the learning curve more steep.
Hang in there and you will be rewarded with a very capable transmitter. I liked mine well enough that I bought a second one as I feel the radio is a very good value for the $$$ spent.
Now if you want easy programming, buy the Hitec Aurora 9. I can't imagine an easier transmitter to program and it has most of the features the 8FG has. I fly the A9 in many of my planes, the 8FG in helis. I chose the 8FG because of its pre programmed compatibility with the Futaba gyros and governor. I also still have and use a 9C and 9Z and agree the 9C was much easier to program than the 8FG .... but nowhere as capable of a performer.
One suggestion regarding the 8FG input device ..... use a light touch on it. That might be your scroll problem. Mine seem quite sensitive ...... it will fight you if you fight it. Relax and take it easy ...... it will work 100% as advertised.
Banned
"Is it just me or is the new Futaba 8FG Super just about the most complicated radio system ever devised"
I don't know. When the 8UAF first came out, I remember Don Edberg marketing his "how to" cook book. Computers are computers. The more capability there is , the more difficult to understand.
Les
Les
I find it a very easy system to program even with its extreme flexibility. The key is to understand it is function based programing, not channel based programing. By that I mean you have to think about functions, e.g. ailerons, elevator, and not channels, e.g. channel 1,2. The function menu is where the functions and channels come together. After two years of using it, I liked it so much I just bought a second one for backup.
Bruce
Bruce
My Feedback: (25)
I'm sorry, but this is not an easy radio to program and I suspect that has a lot to do with why there are so many of them for sale in this and other classified sections. the manual is horrible, it does not even have an index for christ sake and it's full of terms for which there is no glossary to explain what they are. I bought this thing because I was finishing up a 50cc warbird with 10 servos on seven channels plus battery and thought I needed it. then I got a Power Extender Pro and since I use Hitec servos and have a programmer, well it was easy to set it up with my 9C and 8 channel receiver. Now I'm stuck with this thing that will take hours to figure out. But, well since I don't need it now I will play with it a while and see if I see a light at the end of the tunnel.
This was a used radio that had three models in it. I deleted the 2nd and 3rd model, but for some reason it will not let me delete the 1st model that is a helicopter. Can anyone tell me how to delete it. I tried a "data reset" but that didn't do it and when you go into the model it has no delete option like the other two had!
ORIGINAL: splais
This was a used radio that had three models in it. I deleted the 2nd and 3rd model, but for some reason it will not let me delete the 1st model that is a helicopter. Can anyone tell me how to delete it. I tried a ''data reset'' but that didn't do it and when you go into the model it has no delete option like the other two had!
My Feedback: (25)
Well I did just find the Futaba Programming 101 and 102 videos on Youtube. While they use the 14Z it is easy to follow along on the 8FGS. I learned more about the basic programming watching these two 10 minute videos than I did with two hours of trying to make sense out of the manual.
i was and am in the same boat.............i'm going from the old futaba fm radios. i found that sleeping on it and trying again that i'm getting the menus down and am about ready to get into the advanced programing. you can try this link also.
http://images.rcuniverse.com/forum/u...40/Sq46122.pdf
My Feedback: (19)
ORIGINAL: splais
My Feedback: (19)
ORIGINAL: splais
but sir, you are a whiz, some of us are just ordinary. As stated, the futaba programming videos where a great help and much better for getting started than the manual for ordinary mortals.
You can learn the 8FG programming, you just have to stick with it. Be prepared to read between the lines in the book. You've mentioned several problem areas you're having and that the info isn't in the book. I can assure you it is in there .... you're not looking closely enough. Experiment if you don't fully understand a function. When you have specific questions .... forums can help. But please don't come on here and whine about how hard the radio is to learn. I'm sure there are many people with less mental ability than you have that have mastered this radio. Remember when all else fails, RTFM!
In the next few weeks, I have to learn two very complicated new systems at work. I'm not looking forward to this as I know it will be hard work. I know I will have times when I'll get very frustrated. I'll cuss the developer for not knowing what he is doing or for being out of touch with the real world. But I'll stick with it, make sure I have a good grasp of the basics, I'll stick with it then things will start to come together.
Hang in there and report back when you're an 8FG expert. You will be soon if you apply yourself!
My Feedback: (16)
I too am just learning it. I have had 9Cs and 10Cs and it is just different. I had fits of starts and stops, let my brain cool off a bit and go again.
What I have learned is that it dosn' t transfer from the 9s or 10s. Throw that knowledge out and start again with the new manual and the examples. Follow them carefully. It will come to you. The manual is quite thorough.
onward and upward! You can do it.
Slopoke
Slopoke
I'm anxiously awaiting my 8FGA Super. In the meantime, I'm searching various articles. So far, until now, I've been rather disappointed that nothing seems to be written about the "Super" version of this radio. I'm guessing its simply too new and not too many are out there yet. Glad to have found this string.
I haven't had time to dig around toomuch due to my schedule, but I don't seem to be able to find some info that would be useful for future projects on this radio system...Having said all this, I want to jump in for a second and ask a semi-relatedquestion...sorry folksif this doesn't fit within this particular topic...
Has anyone found where Futaba and/or Tower/Hobbico has listed pricing ontheir S-Bus system parts and components?
Herb Air,
Any 8FG becomes a "Super" as soon as you update the software. The only hardware change with the Super was a change to the length of the tabs on the sliders. The originals ones were a little short, and that made them a little hard to get a grip on at the ends of the travel. The slider part is user replaceable, so older ones can be upgraded. Other than that, there's just the changes to the silkscreen printing on the radio[8D]
Pete
Pete
Thanks Pete!
I did read and understood all that...just had a hard time on deciding which way to go. I was considering the older 7C, but decided to move a notch above. Mostly budgetary issues prior to the decision to go with the 8FGA. Some of S-Bus items are still somewhat of a mystery at this point. Much to learn, but not afraid or concerned. However, I'm anxious seeing new posts to this thread.
Herb
Like the reference to Red Green...one of my favorite shows!
Remember: The only time you have too much fuel is when you are on the ground and on fire!
My Feedback: (25)
So I have to apologize to the manual. somehow I missed the table of contents, don't know if the pages were stuck or what but that makes things a heck of a lot easier. For anyone learning this radio those 2 Youtube videos by futaba (Programming 101 and 102) are a great help. they are using the 12Z, but it is very easy to follow along on the 8FG. And yes after those videos and finding the table of contents I am starting to get the hang of it.
My Feedback: (19)
ORIGINAL: splais
So I have to apologize to the manual. somehow I missed the table of contents, don't know if the pages were stuck or what but that makes thinks a heck of a lot easier. For anyone learning this radio those 2 Youtube videos by futaba (Programming 101 and 102) are a great help. they are using the 12Z, but it is very easy to follow along on the 8FG. And yes after those videos and finding the table of contents I am starting to get the hang of it.
I found the 8FG a real pain in the azz. But as someone else has mentioned, once I threw out everything I new about Futaba radio's it got much easier. Every bit of the terminology is different and how it's used. Now, a year later, it's seem's so simple. Plus recently was considering buying a new radio with more channels and wah-lah Futaba give's us the FREE upgrade. Gotta love it.
My Feedback: (9)
WA
I've had mine since summer now and still have to struggle a bit when programming triple rates to the switches, and the throttle down and cut controls. I've found that in addition to the videos, using the servo screen does indeed speed up the programming because you can see what the control output is immediately. I also found that learning the "trick" of tapping the wheel to skip to the top of pages as opposed to scrolling speeds things up. I also bought two, one for my helis and one for fixed wing. I have all the planes/helis programmed into both (on the cards at least) so I can use either tx. As for deleting the last model, create a "new" model and then select it. Then select the one you want to delete and it will ask select, copy, delete. Then delete.
Sam
Sam
