Futaba S3003 servo mounting
I just bought a 9C with the 3003 servos. When I went to mount the rubber insulators on the servos I found that there was no opening in the end of the hole ... there was plastic all around the hole. I had to take out my Dremel & cut a small opening to allow the rubber insulators to slide in.
Never had 3003s before ... is this a new "feature" by Futaba ??
