Switch Designation For Dual Rates
I've heard you can change switch designation on the Futaba computer 8UAPS.
It would be nice to flip one switch to go from high to low rates
on rudder,elevator and ailerons for wild stuff to normal flying.
I've looked at the manual but can't seem to locate the section
on this subject.
Can anyone point me to the right section in the manual?
Is there a reason I would not want to do this.
on this subject.
IL
hi rapid! yo bet. page 27 of the A version of hte manual, second diagram shows the switch assignment.
select hte dual rate you want to reassign. then cursor over until SW-XXX is blinking and change it to the desired switch. that's it!
Thanks, AnnMarie
I couldn't see the forest for the trees.
I kept looking for switch assignment or
switch designation.
I should have checked the Dual rate section
Thank you very much, Bob
switch designation.
