XP9303 Fuse
XP9303 Fuse
Does anybody out there know what size is the fuse in a XP9303 JR Transmitter. After using mine for 2 years I finally managed to plug in the peak charger with the wrong polarity. I replaced the fuse with one I had on hand and got in my flying day but would like to get the right size back in there and I have lost the original.
Also, does anyone know what the output spline is on the HD1214TH servo is (hi-tec, futaba, JR). Thanks for any Info. you can help me with...........RJ
RE: XP9303 Fuse
ORIGINAL: RJConnet Does anybody out there know what size is the fuse in a XP9303 JR Transmitter. After using mine for 2 years I finally managed to plug in the peak charger with the wrong polarity. I replaced the fuse with one I had on hand and got in my flying day but would like to get the right size back in there and I have lost the original. Also, does anyone know what the output spline is on the HD1214TH servo is (hi-tec, futaba, JR). Thanks for any Info. you can help me with...........RJ
3amp, 125volt/250volt fuse are available fromRadioshack..
The volts dont matter, so 250V is fine, just make sure you get the 3amp standard fuse.
Keep a spare as the fuses are easy to blow, sometimes plugging the wall charger in is enough
if wall charger is switched on beforehand
Remove rear of Tx case,replace the fuse just above the battery box.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
RE: XP9303 Fuse
Thanks Alan, I got the fuses at Radioshack today and installed one. Let me also thank you for everything you do in these forums for all of us RC'ers........... RJ
