Futaba - Fp T T7uap ? How To Change Models # S
IL
the modulation type is stored in each model memory. so if you are changiing back to model #1, and it is ppm, the radio will change back to PPM. unless you go into model 1's modulation setting and change it back to PCM (or vice versa.)
