JR XG11 SD card
1 Post
RE: JR XG11 SD card
According to the instructions you can. If you are using the 0001-xxxx software there will be some functions from the 0002-xxxx update that are not set as they didn't exist when the file was written. If you are using 0002-xxxx those functions will be there. Also there are a few differences between the switch types for the new XG11(3 position rather than 2 position in the same location as well as analogue throttle trim if specified) so it will have to sort itself out there too. The instruction manual is greatly improved though still not perfect and is available for download on the JR site at this link. It is a common manual for the XG11, 11X Zero and DSX11 as they are all using the same software.
http://www.jrpropo.co.jp/english/dl/...&db_flg=eng_dl
The latest software is here.. together with instructions for loading.
BEWARE, YOU MUST BACKUP ALL YOUR MODELS TO A SD CARD BEFORE THE UPDATE STARTS OR YOU WILL LOSE ALL YOUR MODEL DATA.
I hope this answers your question.
