Setting up Flaps on a Futaba 9C
some help please? i'm trying to set up flaps on to a 3 poistion switch - so that i can have effectively 2 flap settings. i don't want to use a rotary or slider. i have looked at the Futaba web site the manual and local distributors - but they've not been much help. has anyone done this? if so could they detail the way to do it?
ta
ta
IL
9C flaps on switch
TA,
visit www.futabarc.com and download the us manual. hopefully you'll like it! (i wrote a lot of it.)
as far as flaps on a swithc, this ones easy. go to basic menu, to aux-ch. select your flap channel (6 i assme) and assign it to the desired channel.
Sincerely,
AnnMarie Cross
President
Crosswinds Equine Rescue, Inc
http://hometown.aol.com/horses5ormore/homepage.html
Sincerely,
AnnMarie Cross
President
thanks for that - howver (it must be me being stupid), but i still can't seem to set, effectively 3 flap settings/ i.e Full flaps, half flaps and no flaps - preferably assigned to SwC.
ta
ta
IL
Ta,
You'll need to adjust your linkage setup, or your end points (no flap = ATV on one side; full flaps = ATV on other side) and the center is set with subtrim.
