motor for 3cell lipo
Reply
Old 06-26-2012, 02:50 AM
szewang2805
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default motor for 3cell lipo
hello,
what motor would i use for 3cell lipo
thanks
szewang2805 is offline
Old 06-26-2012, 02:53 AM
Rodney
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: motor for 3cell lipo
Depends on the maximum current capacity of the battery. Pick one that will not draw more current than the battery can safely supply at full charge.
Rodney is offline
Old 06-26-2012, 05:11 AM
BuschBarber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: szewang2805
hello,
thanks
There are many motors that will run on a 3cell LiPo and many that will not. The motor will be driven by an Electronic Speed Controller. You need to look at the specs on the ESC and Motor to determine what is the maximum Current and Voltage that they can handle. A 3cell LiPo charges to 12.6v. The Motor you choose depends upon the aircraft you are going to put it in. The Diameter and Pitch of the Prop you choose determines how much Current you will be drawing.
If you are flying an ARF, you can usually find info on what Motor, ESC, and Battery to use from either the manufacturer or from threads on various forums that are focused on that particular aircraft.
I have some flat foamies that can run on 2cell or 3cell LiPos. The 2cell LiPo is lighter but provides less power. The Capacity of the LiPo determines the Duration of the flight.
BuschBarber is offline
Old 06-26-2012, 08:42 AM
rmh
rmh's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How long is a piece of string?
rmh is offline
