pinion gear
Reply
Old 06-27-2012, 02:15 AM
szewang2805
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default pinion gear
hello, what kind of pinion gear i need on this motor?
i want to upgrade my older byggy to brushless and use lipo 2s battery.
the pinion i have now is with 20T
Here is the details :
LEOPARD SKYRC 3300KV 12T Brushless Motor & 60A ESC Speed Controller Combo
Motor Specifications[/b]
Rotational Speed: 3300 KV
Turns of the Motor: 12T
Max. Amps: 35A
Resistance: 0.0225ohm
Motor Dimensions (Diameter x Length): 35.8mm x 50mm
Shaft Dimensions (Diameter x Length): 3.17mm x 15mm
Input Battery Types: NiCd / Nimh / Li-po Battery
Recommend Model: RC Model 1/10 Car
Net Weight: 172g
szewang2805 is offline
Reply
Display Modes
