Hi/Lo band
Reply
Old 06-29-2012, 07:58 AM
JollyPopper
JollyPopper's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Hi/Lo band
I have two Futaba receivers with channel 36 crystals in them. One is marked "Lo BAND" on the side and the other has a red dot in the crystal slot indicating it is hi band. Did Futaba put channel 36 crystals in both hi and lo band receivers or has somebody been switching crystals in the receivers before I got them. These are not new receivers as they have been pre-owned, but I knew the gentleman who owned them and if they are used, they were used very gently. Unfortunately, I can't ask the previous owner because he was killed in an automobile accident on his way home from the flying field a couple years ago.
JollyPopper is offline
Old 06-29-2012, 08:44 AM
BarracudaHockey
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Hi/Lo band
They were mixing and matching crystals.
Unless you're flying in busy environment at the edge of the receivers range I wouldn't sweat it.
Radio South or Futaba would retune them to the exact crystal you're using (tuning will also uncover any issues with the rx itself) for a reasonable fee if you want some cheap peace of mind.
BarracudaHockey is offline
Old 06-29-2012, 06:26 PM
carrellh
carrellh's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
35 is low band, 36 is high. I do not know if being out by 1 channel matters but I wouldn't risk it.
carrellh is offline
Old 06-30-2012, 12:21 AM
A.T.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: JollyPopper I have two Futaba receivers with channel 36 crystals in them. One is marked "Lo BAND" on the side and the other has a red dot in the crystal slot indicating it is hi band. Did Futaba put channel 36 crystals in both hi and lo band receivers or has somebody been switching crystals in the receivers before I got them. These are not new receivers as they have been pre-owned, but I knew the gentleman who owned them and if they are used, they were used very gently. Unfortunately, I can't ask the previous owner because he was killed in an automobile accident on his way home from the flying field a couple years ago.
35Mhz &36Mhz are treated as separate frequencies (same as 40MHz &41 Mhz).
. Both Tx &Rx are centre tuned within those two separate frequencies.
Hi/Lo Band refers to 72 MZ only, refer:
. Futaba - 72Mhz Hi & Lo Band Difference & Markings
more information available under sub section
"Radio Systems, Accessories, Alterations and FAQ" at
Alan's Hobby, Model & RC FAQ Web Links
which may well provide answers for further questions.
Alan T.
A.T. is offline
Old 06-30-2012, 12:49 PM
BarracudaHockey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Al he's talking about US channels 35 and 36
Futaba center tunes on the lower or upper half of the band. So if have a low band rx thats center tuned to channel 23, and put a channel 36 crystal in, your 13 channels away from the optimal tuning channel.
If on the other hand you have a center tuned receiver (remember, that Futaba didnt do that on all recievers, just for a couple of years on certain models) like any other reciever out there, including most Futaba 72mhz systems, its tuned to channel 35 (the center of the band) and you can put a channel 59 or 60 crystal in it and it will work just fine, yet its now 23 or 24 channels away from its optimum tuning.
Hence my statement, given the stated circumstances, I seriously doubt he will find himself any worse off than anyone else flying a 72 mhz system. Now if he were going to throw that channel 59 or 60 crystal in it, then you might have a case of saying it's not a good idea.
Like I said, if you're that worried, just have it aligned to the actual channel you're flying on.
