Micro switch
Reply
Old 07-19-2012, 07:18 AM
70x7
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Micro switch
(my apologies if this is not the correct forum)
Can someone recommend the lightest possible micro switch/harness? I am wanting to add landing lights to a micro electric. I don't have an extra channel, so I'll tap off the battery lead. A switch would be helpful (so they're not always on). Weight is an issue, since it's micro. I've searched the internet, and all the micro switches I can find don't list weight or size (they are replacement parts for existing systems. I'll be using a 1 cell battery if that makes a difference. Any recommendations?
70x7 is offline
Old 07-19-2012, 12:33 PM
A.T.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Micro switch
ORIGINAL: 70x7 (my apologies if this is not the correct forum) Can someone recommend the lightest possible micro switch/harness?
Unfortunately, the lightest switches with leads generally have the wrong plugs and
changing those plugs can be a hassle. In lieu ofmicro switch harness, DIY with one
extension lead or a servo lead and a mini Deans plug or similar:
.Cut lead to required length for both "switch" and battery.
. Solder battery socket on end if servo lead.
.Cut positive lead in position switch is required and solder onto the two pins of aDeansmini plug or similar.
. Solder small piece of wire to bridge the two pins of a Deans mini "socket", this then forms the switch (or breaker)
similar to using a fuse as a contact breaker on large EP modles. - light, can be fitted to users requirements.
much more information available under
"FAQ = Answers for Beginners and Advanced RC'ers" &
"Radio Systems, Accessories, Alterations and FAQ"
below
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
A.T. is offline
Old 07-19-2012, 06:11 PM
tacx
tacx's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check out Radio Shack on line. They have a few "sum mini" switches. Here is an example.
http://www.radioshack.com/product/in...uctId=12708878
tacx is offline
