Two channel ail, one trim
Reply
Old 07-26-2012, 04:50 PM
Pete S-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Two channel ail, one trim
I know I've done this before, but can't remember how.
I'm programming crow on my ailerons and flaps and so need two separate channels.
I have ail on the right wing and aux2 is operating the left ail.
Trim only works on the ail right wing.
How can I get the one trim to work on both?
I'm using flight modes to turn off the crow if I don't like it.
I'm using a JR 9303 radio.
Anyone done this?
Pete S-RCU is offline
Old 07-26-2012, 05:51 PM
BuschBarber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Two channel ail, one trim
ORIGINAL: Pete S-RCU
Anyone done this?
I have the 9303.
The proper way to set up Dual Ailerons is to go into the System Menu, set Wing Type to Normal. and use the Mate function to mix the Ail channel with the Aux 2 channel (in this case). Make sure to go into the Device Select menu and set Aux2 switch to Inh. Both Ailerons should respond to the Ail Trim.
BuschBarber is offline
