airtronics rd 8000 CHARGING
NJ
can i fast charge my rd 8000 transmitter with the battery in the radio or do i have to take it out ? also my old radio was jr will the charging plugs i made up be the same polarity?
NC
JR transmitter charge plugs are OPPOSITE polarity from Airtronics, Futaba, and Hitec. To address your other question, you can fast charge the battery in place in the transmitter ... I have always felt it was safer to fast charge with the battery out of the transmitter. I have flown the Airtronics Infinity 660 series for several years and now have a Stylus and the battery is made to be removed quite easily from those .... as a matter of fact, I believe Airtronics even suggests fast charging with the out of the transmitter. I must admit, though, I have never had any problem associated with fast charging and I have used AccuCycle Plus in the past and now am using a Sirius fast charger.
Again, the polarity of the JR transmitter leads is OPPOSITE that of Airtronics, Futaba, and Hitec.
NJ
isn;t there some sort of diode in the radio that dosen;t allow this also they recommend some sort of special charging plug do you know any thig about this?
