Carbon Cub SS binding
CA
I just bought a new Carbon cub ss and a new Spektrum dx6i. There where no instructions with the plane. I new to this sport. How do You bind the two together. Thank you so much for some help so I can fly tomorrow.
Allen
Allen
RE: Carbon Cub SS binding
First you should plug in the battery to the carbon cub. There should be a blinking LED on the inside of the plane a couple seconds after (just look in through the nose of the plane). Then, hold the trainer switch on the top of the DX6i while turning on the transmitter, and when the light in the plane goes solid, it should be all bound up.
ORIGINAL: rhd-RCU
Pull the foam from the box. The instructions are taped to the bottom of the foam.
CA
Your Right, behind the foam. I will read and see if I can get it bined.
I will keep you guys posted
Thanks so much for the guidance.
I have a private 3 acre lake in my back yard. Time to fly off the pond. I've been running some insane boats. Now I want to learn to fly.
Allen
Allen
