How much were we at risk
My Feedback: (13)
1 Post
Flying with a buddy, I noticed only 4.6 volts on his TX (Spectrum 5x?) He had 4 1.5V rating NIMH batteries. I'm not familiar with Spectrum or even 2.4 radios, I only use 72 MH 8 cell TX NIMH/NICADs. But, old worrywart me, I suggested he change batteries and the new dry cells 1.2 volts read out 6.5V on the TX. I used his transmitter and flew about a 6 minute flight. So, were we at risk of a crash during this short flight with the original batteries? Thanks!
RE: How much were we at risk
That was a very good move on your part as quite possibly your action saved his plane as 5.0 volts is the recommended minimum Tx voltage for alkaline batteries.
Karol
Karol
That transmitter will work very safely down to 4.4 volts. At that point you would still have plenty of time to safely land your plane. At 1.1 volts/cell a Nixx battery still has about 20% or its useable power left.
My Feedback: (13)
1 Post
Thanks, So at least a Spektum TX can throw out a sufficient signal only using 4 cells down to 4.4 volts. Is that basically due to the 2.4 technology over the old 72 MH tx technology?
Nimh batteries are rated nominal 1.2 volts per cell and considered drained at .8 volts per cell. Normally you would stop flying at anything below 4.8 volts with a good margin for safety. 4.6v should not have been an issue for short flight. Disposable batteries are rated ar 1.5 volts per cell.
My DX8 runs off a 4 cell Nimh, and it normally reads below 5v, and has an alarm when the voltage drops to a low level with enough time for you to land. What is freaky is at full charge the meter on the TX is only at half bar. The TX can take a Lipo instead and it will show a full bar. I am considering it, but get enough time out of the pack for a night of flying with plenty left over.
ORIGINAL: acdii
the std battries - NIMH- need occasional charging - when the y finally get to 4.6 or so, 5-8 hours typically fills em up . never a need for field charging
The only problem I have seen with these batteries is overcharging -typically by those who think the battery drain is like the old 9.6 tx and want full batts for each flying session- .
As A Kunz noted the electronics run at 3 volts -just a trickle of current .
Typically, users go weeks even months without a recharge. We see lots of DX8's, this is not unusual
