JR 791 retract servo with LiFe pack.
Reply
Old 08-31-2012, 11:08 AM
radfordc
My Feedback: (14)
radfordc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default JR 791 retract servo with LiFe pack.
I'm using a JR 791 retract servo in my TF P-47 ARF and I'm also using a 2 cell A123 LiFe pack. When I first connected the servo I was surprised to see that it didn't work, but I quickly found out that these servos will only work with 4.8 volts. In order to make the servo work correctly I needed to drop the voltage. The way I did this was to add 2 diodes in series in the servo extension lead and this seems to be working so far.
Anyone see any problem with this approach, or have a better solution?
radfordc is offline
Old 08-31-2012, 12:12 PM
pilotpete2
pilotpete2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: JR 791 retract servo with LiFe pack.
As long as the diodes are of adequate size to handle the current and aren't getting too hot when the gear cycles you should be fine. Heck, whats the worst that can happen, a gear up landing if a diode fails[&:]
Pete
pilotpete2 is offline
Old 08-31-2012, 12:20 PM
radfordc
My Feedback: (14)
radfordc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think the "worst" would be a half way gear up landing!
radfordc is offline
Old 08-31-2012, 02:21 PM
aghost
My Feedback: (13)
aghost's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use LiFe batteries and need 4-cell voltage in a couple of planes for specific items. JR has a 2 Channel Voltage regulator I use. At $30, the diode's are probably cheaper.
This solution is not necessarily better, but here is a link to the item.
Brian
aghost is offline
Old 08-31-2012, 03:10 PM
pilotpete2
pilotpete2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: radfordc
I think the ''worst'' would be a half way gear up landing!
I think you be right
Pete
Old 08-31-2012, 05:25 PM
Truckracer
My Feedback: (19)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: pilotpete2
Pete
+1
The diodes should be fine. I would use ones rated at 3 Amps rather than the 400X series that are so common and rated at 1.0 A! These should be available for pennies each.
Truckracer is online now
Old 09-01-2012, 04:59 AM
BuschBarber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Truckracer
Pete
+1
I have an H9 P47-150, with a 791 Retract servo on each Main gear.. I use a Castle Creations BEC Pro and a 2500 LiFe pack with JR921 Rx. Never a problem.
BuschBarber is offline
Old 09-01-2012, 03:49 PM
radfordc
My Feedback: (14)
radfordc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think that a voltage regulator is a better solution. The plane has a redundant battery system...two 1300 LiFe batteries and two switches. I'm going to add two Turnigy VRs ( http://www.hobbyking.com/hobbyking/s...idProduct=4319 ) and this will reduce the system voltage to 5v and provide up to 6 amps of current. Less than $10, too.
radfordc is offline
Old 09-02-2012, 06:54 AM
dirtybird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: radfordc
I have to disagree with you. Two diodes are a simple solution that will be bullet proof it the diodes have the rated current. A regulator has many parts to fail and getting one one from Hobbyking is questionable in itself
dirtybird is offline
Old 09-02-2012, 11:11 AM
radfordc
My Feedback: (14)
radfordc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Your right about the diodes being more reliable than a VR. But, the servos that I'm using are Hitec and are not rated for 6 volts so I'm taking a risk by running them on a LiFe pack. I've already had to replace a couple of jittery servos and the high voltage may be the problem.
Using 1 cheap VR would indeed be a high risk, but by using 2 in parallel the risk is greatly reduced. Part of the preflight check is to be sure that each battery, switch, and VR is functioning properly independent of the other. If one VR fails in flight the other one will continue to provide power. Both VRs would have to fail for a total failure.
I am using several different types of electronics (receivers, voltage regulators, servos, etc) from HobbyKing and am totally satisfied so far.
radfordc is offline
Old 09-02-2012, 12:49 PM
dirtybird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Two diodes in series will reduce the voltage to 5.1V.
