AR500 Thoughts ?
Reply
Old 09-16-2012, 08:17 AM
BillinIndiana
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default AR500 Thoughts ?
I seen a Spektrun Full Range AR500 Rx on E-Bay for $23.. When I Google'd it, a lot of "complaint" search results came up.. Just curious if anyone here has had one of these Rx? Should I stay away from this Rx? Would it be a good Rx for my Sig MK II trainer?
BillinIndiana is offline
Old 09-16-2012, 08:22 AM
BuschBarber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: AR500 Thoughts ?
ORIGINAL: BillinIndiana
I seen a Spektrun Full Range AR500 Rx on E-Bay for $23.. When I Google'd it, a lot of ''complaint'' search results came up.. Just curious if anyone here has had one of these Rx? Should I stay away from this Rx? Would it be a good Rx for my Sig MK II trainer?
I have a friend who has one in a Blue Hawk Ultimate bipe. No issues.
BuschBarber is offline
Old 09-16-2012, 10:20 AM
rmh
rmh's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ditto never a seconds trouble
However the new ar400 is a cut above it in antenna setup - and 30 bucks
Also the AR500 is actually a 4 channel with two aileron port locations !
product for the price - the new AR400 is an easy winner
PS I also use these - work great at any distance
rmh is offline
Old 09-16-2012, 02:39 PM
BillinIndiana
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank You
Old 09-20-2012, 06:07 PM
geeter
My Feedback: (110)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i also have both rx's the AR500 i have had for three years........no issues at all. the new AR400 i have works very well also. .....RON
geeter is offline
Old 09-21-2012, 03:36 PM
SkidMan
My Feedback: (17)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have one in a glider that I fly on the edge of visual range without any issues.
Paul
SkidMan is offline
Old 09-21-2012, 04:05 PM
AB Bob
My Feedback: (20)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If it's an older one. I'd be sure to run it with a 6V battery. I run all my RX's with 6V batteries.
AB Bob is offline
Old 09-22-2012, 08:15 AM
P-40 DRIVER
P-40 DRIVER's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The AR500's had issue which occured in a multiple plane enviroments. I can't remember the exact details but it was discontinued.
P-40 DRIVER is offline
Old 09-23-2012, 07:51 AM
rmh
rmh's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Be careful! the 500 is a four (4) channel rx with two plug sockets for aileron channel
spend the 30 buckson the new AR400. better -upgraded rx and secondary rx.
rmh is offline
Old 09-24-2012, 06:07 PM
snuts
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
rmh, I must correct your statement. (I was going to let it slide the first time) The AR500 is a 5 channel receiver with a 6th port, as a "Y" for the ailerons.
I have a few, at least three in use. I often mate the fifth channel as 2nd aileron in my 9303, 9503, or 12X to take advantage of aileron differential. I never use the 6th port, other than possibly a second battery input.
As for advise, I would recomend the AR600 over the now discontinued AR500. The antenna configuration in itself is well worth the newer design.
Hope this helps,
-Snuts-
snuts is offline
Old 09-25-2012, 03:37 AM
rmh
rmh's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK- - I did not go look - my last 5 is in a foamie just remembered the Y setup on aileron- anyway the four has an improved antenna system.
As does the 6 channel - The gear /aileron mix was the fix on those -as you noted -to get split aileron function.
rmh is offline
