Turnigy 9x programming
Hi,
I have a Turnigy 9x radio. I recently had to replace the motor on my plane - and after I did, things don't work the same.
I have to push the throttle half way up before the motor will ingage. Consequently, the top prop speed is only half of what it was and I doubt the plane will take off. I supose it could be the motor, but that is unlikely (the motor has the same specs as the previous motor).
I was wondering if I can program the radio to make motor start turning at the beginning of the throttle throw (rather than the middle). Is there a way to do this (besides trim? - trimming all the way didn't make much of a difference.
Is it possible I changed the ESC programming with my soldering? I hope this isn't the case - I have absolutely no idea how to reprogram the ESC. I doubt I have the tools to do it anyway.
Thanks!
Thanks!
My Feedback: (325)
RE: Turnigy 9x programming
Could you tell us what esc and plane you have exactly? I think it is the problem. Please also check the "display" on the 9x while working the throttle.
I don't know the exact ESC.
This is the plane - it came with the ESC. I'll look and see if I can determine the make.
http://www.hobbyking.com/hobbyking/s...dProduct=16657
I didn't recalibrate anything - just unhooked the old motor, and put the new one on.
My Feedback: (325)
If the throttle on the 9x display and all other channels work ok then it is probably an esc. You could just plug a servo into the throttle channel and see if it has full swing.
