LiFe battery + regulater in a Hitec A9
Is anybody using the above combo in a Hitec Aurora 9 transmitter? I asked the question of Hitec about it and the Life battery voltage is to low on two cells so three would be necessary. At three cells the voltage is to high so a reg is needed.
I'm not a fan of leaving a Lipo in a charged state for very long. Or am I making a mountain out of a mole hill in this application?
Ken
Ken
RE: LiFe battery + regulater in a Hitec A9
2S Lipo is the correct voltage for that radio. Just make sure to get a 2S Lipo that is made for transmitter use with a low C rating. The higher the C rating on a Lipo, the greater the problem leaving it fully charged for extended periods.
The A9 is a 6 Nimh cell radio just like my Futaba 8FG, I can use a LiFe 2S. Futaba even tells you what to set for a low voltage warning for LiFe (6.4V), but I use a 2S Lipo made for the 8FG.
Pete
Pete
ORIGINAL: kenh3497 Is anybody using the above combo in a Hitec Aurora 9 transmitter?
Ken
Ken
" LiFE battery should not be used in the A9 because the voltage is too low.
A 2 cell LiFE has a nominal voltage of 6.6 and a full charge voltage of 7.2.
They usually drop to about 6.8v pretty quick so it will be under the low voltage alarm
of 6.9v in just a few minutes."
3S LiFe, if a pack can be found that will fit, will definitely require a regulator of some type set to max 8.4v.
2S Lipo. There is no problem with the low drain 1C/2C purpose sold for use with transmitters,
they can be left charged for extended periods. However, please refer to:
. Aurora 9 - Lipo User Adjustable Voltage sets Shut Down = TURNS TX OFF to save damage to Lipo Battery and/or TX
(Audible Battery Warning is still at 6.9V with Lipo which provides say 10-20 min before shutdown.)
. Aurora 9 - Warning Alarms Battery types, Voltage Level Interpretation & Consumption.
CAUTION - Leave Auto Hibernation (was Auto Power Off prior to V1.06) as "Never" when using Lipo Battery.
During "Auto Hibernation" (as with laptops) TX Does Not Switch everything Off and batteries will be completely drained if
TX switch is not manually moved to the off position in good time.
Remove battery and store separately if TX is to be unused for a period.
A picture, showing user suggested fitting of a Lipo pack for easy removal/replacement, is attached to:
. Aurora 9 - Lipo & Field Charging. includes Fast Charge Aurora, Eclipse 7, Flash 4&5, Laser, Optic 6, Prism 7 etc.
ex Hitec USA Support Forum Sticky:
Aurora 9, AFHSS Modules, Optima & Telemetry
- FAQ & Undocumented Features
- Mixes, Setups,Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
ORIGINAL: A.T.
http://. Aurora 9 - Lipo User Adjust...sets Shut Down = TURNS TX OFF to save damage to Lipo Battery and/or TX
Thank You
Ken
AZ
ORIGINAL: canavanbob
Have you thought of using Eneloop batteries?
