8FG SUPER
Reply
Old 10-20-2012, 07:28 AM
spinmeister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 8FG SUPER
I have a Futaba 8UAF that I've had for years and it performs well. I've only been flying a little bit the past few years and am ready to get back in all the way. So I bought a Futaba 8FG SUPER. It looks great but I don't know if I'm just getting old, but in the first half hour of trying to use it, it sure appears to be a pain. I took the 8UAF out of an Extra that I've had and want to install the SUPER. I have 2 aileron servos y'd to one plug. I have two elevator servos, one throttle, and one rudder servo. Can some please just walk me through setting them up. So far it appears that I'm going to have to change my whole thought process over what I've learned in the past. I can't even find the place for servo travel limits and reversing. Someone please lend this old man a hand. Thanks.
spinmeister is offline
Old 10-20-2012, 08:13 AM
BuschBarber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 8FG SUPER
Quote:
ORIGINAL: spinmeister
I had the 8AUPS for years before I bought the 9CAP. I set up the Ailerons using the Flapperon program, with the Right Aileron connected to the Aileron Ch1 and the Left Aileron connected to the Flap Ch 6. I set the Flap component to Zero unless you plan on using the Ailerons as Flaps. I set up the Elevators using the Ailevator program. The Right Elevator servo is connected to the Elevator Ch 2 and the Left Elevator servo is connected to Aux 3 Ch 8. Be sure to dial out the Aileron component so that the Elevator halves do not react to the Aileron stick. The original purpose of the Ailevator program was to allow the Elevators to work as both Elevators and Ailerons. This worked for my F16 jets that had Flying Stabs, which replaced the need for Ailerons. I haven't, however, seen anyone use Elevators as Ailerons or in conjunction with Ailerons on an Aerobatic plane. Ailevator worked fine for mixing Dual Ailerons.
On newer radios with multiple choices for Wing Types and Tail Types, there are better ways of doing this.
I gave up on Y Harnesses years ago. Especially Reversing Y Harnesses. Too many servo issues as a result of bad Y's. I would use a JR Matchbox or Futaba Servo Syncronizer before ever using a Y.
BuschBarber is offline
Old 10-21-2012, 04:47 AM
dbar101219
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have had that radio for a year now and love it here is the a form that might help
http://www.rcgroups.com/forums/showt...ight=flaperons
the more you use it the easyer it gets good luck
dbar101219 is offline
Old 10-21-2012, 05:03 AM
karolh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guess it's a case of different strokes for different folks as I still use my trusty 8UAF Tx as I just love how it feels in my hands, plus it has performed flawlessly. When compared to current models I guess it has it's limitations but IMHO I think it's one of the best radios Futaba ever made.
Karol
karolh is online now
Old 10-21-2012, 06:35 AM
BuschBarber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I guess I misread your post. I thought you were talking about the 8AUFS. I do not have the 8FG. Sorry!
Old 10-21-2012, 07:35 AM
Roo Man
Roo Man's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Spinmeister,
I think this web site will help you. Select the model manual you need [note you will have to select the 8uaf and it will take you to the super] and then you can print it.
http://www.futaba-rc.com/downloads/manuals.html
I have the 8UAP with an after market 2.4 conversion and love the transmitter.
Gary
Roo Man is offline
Old 10-21-2012, 10:14 AM
DougV
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hope this FUTABA 8FG- SUPPLEMENTARY NOTES from Malcom Holts will help you understand the power and flexibility of the Futaba 8FG.
Enjoy it, it's an awesome radio.
Doug.
File Type: pdf
DougV is offline
Old 10-27-2012, 11:17 AM
spinmeister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the help. I'm slowly figuring it out. I got everything working including the dual rates and switch assignments.......that was something new to me. One thing more though. I currently hooked the radio up in a plane that does not have digital servos. When I move them all the way one way or another, sometimes the servos seem to "flutter" for a moment and then stop. If I move the stick slowly to the end point, they don't do it, but if I move it quickly, the "flutter" happens. Any ideas?
Old 10-27-2012, 11:51 AM
TimBle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you may have the Receiver in high speed mode. If you power up the Rx without the Tx on, does it first flash Red/Green (Orange) before going Red?
TimBle is offline
Old 10-30-2012, 03:37 PM
spinmeister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't think so but I'll check it tonight.
Old 10-31-2012, 09:45 AM
Bax
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's the 8FG FAQ page:
http://www.futaba-rc.com/faq/faq-8fg-2_4ghz.html
A bit about the thinking process used in programming can be found starting at FAQ #9.
Bax is offline
Old 11-01-2012, 02:52 AM
spinmeister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks. This radio does way more than I thought it did....or really need. I'm sure I'll "need" it once I start using more of the functions.
Old 11-01-2012, 06:06 AM
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The menu system is a bit confusing, especially if you are used to the Spektrum menus. Once you get the hang of the menus though, the setup is fairly straight forward, the trick is remembering HOW you got to a particular menu.
The one thing I dont like about the 8FGS is to get into range check, you have to hold the touchpad down while turning on the radio, where the DX8 you just scroll through to the range check menu and hold down the trainer switch.  If for some reason you had already started the engine and want to do a range check while it warms up, you have to turn off the radio, and well, if you dont have your fail safe points setup just right.........
Aside from that, its a very good radio.
acdii is offline
Old 11-01-2012, 07:20 AM
John Sohm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks. This radio does way more than I thought it did....or really need. I'm sure I'll ''need'' it once I start using more of the functions.
Better to have and not need than to not have and need . Once you get used to it, you'll really like it. Right now, it's probably the best bang for the buck going for the average to advanced modeler. I like mine a lot.
John Sohm is offline
Reply
Display Modes
