Flaperon or Ail-Dif for 9c set-up??
I'm using two servos in the wing of my Venture, one for each aileron, but don't intend on using flaperons and don't have flaps. Which "program" do you think I should use on my 9c?
My Feedback: (72)
RE: Flaperon or Ail-Dif for 9c set-up??
Setting up flaperons still allows you to program in differential, and also gives you the option of trimming the flaps or utilizing them if you change your mind.
