If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 4 of 4
  1. #1
    Malcolm H's Avatar
    Join Date
    Oct 2002
    glasgow, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    PCM10X Backup Battery
    Can anyone tell me if the backup battery in a JR PCM10X is draining all the time or does it only drain when the main battery is removed/flat?
    Also can the data be retained during backup replacement by the main battery?
    Malcolm
  2. #2
    Join Date
    Mar 2008
    Sluff, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: PCM10X Backup Battery
    The lithium cell supplies the memory when the set is switched off. However, the onboard capacitor will supply sufficient power for a couple of days before the cell kicks in
    Yes it is quite normal for all memories to be safe
  3. #3
    Join Date
    Jul 2002
    Auckland, NEW ZEALAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Malcolm H Can anyone tell me if the backup battery in a JR PCM10X is draining all the time or does it only drain when the main battery is removed/flat? Also can the data be retained during backup replacement by the main battery? Thanks, Malcolm
    As in post #2, provided a JRTx is turned on for a few moments every second day, the capacitor saves drain on the battery.
    This will provide 3<5 years life for the on board Lithium button cell but even 7 years has been realised by frequent users.
    If replacing the button cell is not done correctly, then user will loose their model data, the following may assist:
    . JR - DIY Replace back up Lithium Memory Battery
    . JR - DIY Replace back up Lithium Memory Battery (Pictorial)
    Good photos and schematics to use a cell holder rather than hard solder to board
    . Reviving My Old Glory JR X347 PCM Transmitter
    with more under sub section
    "Transmitter - FAQ - Additions, Adjustments, Mode Change, Clonepacs & Repairs."
    below
    "Radio Systems, Accessories, Alterations and FAQ" at
    Alan's Hobby, Model & RC FAQ Web Links
    Alan T.
    R/C hobby consultant for various companies
  4. #4
    Malcolm H's Avatar
    Join Date
    Oct 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks guys,
    Malcolm
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
