Hobbyking RX3S Flight Stabilizer
Reply
Old 10-31-2012, 03:41 AM
mjunior
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Hobbyking RX3S Flight Stabilizer
Have you guys tried it in glow powered models?
http://www.hobbyking.com/hobbyking/s...tabilizer.html
Any thread about it?
Regards
mjunior is offline
Old 10-31-2012, 05:30 AM
dirtybird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Hobbyking RX3S Flight Stabilizer
I have a couple of them. I expect to try them soon.
There is a lot of info on Hobbykings comments with the article
dirtybird is offline
Old 10-31-2012, 05:54 AM
mjunior
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes but I couldn't see precise information about the results in glow powered models. I'm affraid the natural vibration of those models will affect the stabilizer performance.
mjunior is offline
Old 11-01-2012, 09:22 AM
dirtybird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I wouldn't expect vibration to cause any problems if it is mounted securely to prevent movement independent of the aircraft. They are all solid state components. Its not like a spinning flywheel gyro.
Old 11-18-2012, 04:56 PM
bicyclemonkey
bicyclemonkey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
We tried this on a friends Pitts with a DLE-30 this weekend and it worked amazing!  The plane was very sensitive, squirrely, and, twitchy in the air before...it was quite a handful.  After the gyro, it settled down nicely, he loves this plane now.
bicyclemonkey is offline
Old 11-19-2012, 10:41 AM
dirtybird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have one on an old Lazy Ace. I have the gain on the aileron turned all of the way down and it still hunts little bit when I give it full throttle. I am going to cut down the aileron servo movement mechanically and try again tomorrow.
Update
I was turning down the yaw pot and not the aileron. Its hard to read in the bright sun. I now have the aileron pot set at about 50% and there were no hunting.
Old 11-19-2012, 11:19 AM
mjunior
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: bicyclemonkey
Good news. Do you know how much gain is set for each control?
mjunior is offline
Old 11-19-2012, 11:32 AM
bicyclemonkey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: mjunior
We tried this on a friends Pitts with a DLE-30 this weekend and it worked amazing! The plane was very sensitive,squirrely, and, twitchy in the air before...it was quite a handful. After the gyro, it settled down nicely, he loves this plane now.
I don't remember which was which but two were at 25% and one was 50%. (I think)
Old 11-19-2012, 02:09 PM
rmh
rmh's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am going to get a couple -
After buying some of the little Bind n Fly AS3X arobatic types -it is obvious how well a properly setup gyro can make an otherwise "bright' model and make it feel much larger and solid.
My radios have very good expo/dual rate etc., adj and I really don't have any issues to fix - just want to see how well it works - I will start with my camera carrying model to see if it smooths up my movies .
rmh is offline
Old 11-23-2012, 07:14 PM
Flypaper 2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have it on an old Zoombi bipe. Made a completely different plane out of it. This was a very violently aerobatic plane with very high throws with lots of expo. With the gyro I had to take out all of the expo as the gyro took over in the stability department. Flies more like pattern plane now and hovering performance is a none issue. Was able to move the CG much further back now because the gyro keeps it much more stable in pitch. Great new tool.
Flypaper 2 is offline
Reply
Display Modes
