Need Help with Spektrum dx5e and binding !
Hi guys just need to ask some questions
Ok so I have the Spektrum Dx5E transmitter, and a spektrum 6ch receiver, I use the reciver for both my models, I just switch it between each plane, I do this because the dx5e has only 1 model memory, but this is the question,::::: If I where to but a new reciver and bind that would I need to rebind with the bind plug every time I wanted to go back to the other one
Thanks for reading replies will be much appreciated , also check out my YouTube channel for on boards, http://youtube.com/user/flyingmaddladd
CA
RE: Need Help with Spektrum dx5e and binding !
If you have 2 of the same type Rxs you can bind them both at the same time and not need to rebind when you switch back and forth between the two.
You can bind as many receivers to your transmitter as you want. The receiver stores the unique ID of the transmitter at binding. Just make sure to only have one model powered up at the same time though
Pete
Pete
CA
You will probably only forget and accidentally have 2 plugged in at the same time ONCE.Its one of those e-ticket incidents that generally gets etched into your mind permanently.
