DSM2 receiver and DSMX transmitter
QC, CANADA
Here is my problem. I was recently given a DSM2 turnigy receiver by a friend. I use a DX8 transmitter upgraded to DSMX.
I have bound the receiver to the radio. However everything turns out to be OK except that the rudder servo jitters continuously.
I have replaced the servo, and the problem persists. I have changed brand of servo and the problem still persists.
Is the problem the receiver or the fact that I use DSMX on a DSM2 receiver ?
I don't have another DSM2 receiver to experiment.
Can I run this type of receiver on DSMX or is it not advisable to do so ?
I have researched the subject and I did not find a definitive answer.
My Feedback: (17)
FL
RE: DSM2 receiver and DSMX transmitter
A couple quick bullet points.
- [*]There is absolutely no problem running a DSM2 receiver on a DSMX transmitter.[*]A DSM2 receiver cannot run DSMX. [/list]
Try running a different servo on the rudder channel to see if it still jitters.
ORIGINAL: tomd-RCU
Do you have any amplified Y servo cables in your setup? Spektrum says not to do that and may have been passed on to the orange products. I have seen a servo on another channel cause a different servo to act up. Start with just the one servo plugged in, if its ok, plug another in and so on. If its still a problem, try a different channel. This should help hound dogging the problem. You may have just been given a bad receiver.
Edwin
Edwin
QC, CANADA
Thank you all with your answers.
There is no amplified Y connector. Like I said, all the other channels are fine except the rudder.
I conclude that the receiver is defective.
QC, CANADA
In my post I said that I concluded that the receiver is defective. It occured to me that maybe this receiver is not compatible with DSMX.
I would like to hear from anyone who has used this receiver ( orange six channel DSM2) with a DSMX transmitter.
I have a couple of those orange receivers on a pair of foamies. My Radio is an older 9303 with a DSM2 spektrum module. Recently, i noticed a little oscillation on the rudder of one of the foamies. Since it IS a foamie I did not pay attention, neither I care. And because they are FOAMIES is the only reason they were outfitted with orange receivers.
The old adage of "you get what you pay for" applies here. I would not use one of those receivers in anything I'd like to take home in one piece day after day.
Rafael
Rafael
