DX7 - Flap Help
My Feedback: (24)
DX7 - Flap Help
I'm trying to set up a Flaps (single servo) on my DX7. I am using an AR6100 reciever and have the flap servo plugged into the AUX 1 Port. I am simply trying to get this flap servo to move when I move either the Flap Mix switch or the Aux 2 switch on the transmitter. I cannot find a way to assign the AUX 1 channel on the reciever to either of these switches.
(the airplane has retracts so I am using all the channels on the reciever).
I have alreday spent way way to much time on this. Any help would be greatly appreciated. Thanks.
CA
RE: DX7 - Flap Help
Bob
Like Andy said first power up into the system menus.Use up/down button to get to the Input Select screen.Use select button to put the arrow next to Flap.Use Increase/Decrease button to select either Rocker or System.Exit back to normal Function menus and you will now have Flap System menu if you selected system(my choice).Set values in Flap menu
Scott.
Scott.
