Tactic TTX 650
My Feedback: (325)
Tactic TTX 650
http://www.tacticrc.com/transmitters...650/index.html Looks pretty good. I hope it is cheap. It will fly all of my Tactic planes?
RE: Tactic TTX 650
ORIGINAL: guver http://www.tacticrc.com/transmitters...650/index.html Looks pretty good. I hope it is cheap. It will fly all of my Tactic planes?
Tactic & AnyLink Support Forum including the new Aurora 9X as attached,
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
My Feedback: (325)
RE: Tactic TTX 650
With other brands of TX one is forced to use the 1000 ft range Tactic anylink. My jury is still out on the anylink , and many anylink set-ups are just plain bad.
RE: Tactic TTX 650
ORIGINAL: guver With other brands of TX one is forced to use the 1000 ft range Tactic anylink. My jury is still out on the anylink , and many anylink set-ups are just plain bad.
"Question: Why can't I use the AnyLink on my larger models?
Answer: AnyLink can be used for larger models, but the maximum specified signal range of AnyLink is 1000ft."
However, given the loss of many flying fields and cost to travel long distances to others, the "Parkflyer" is
once again the most popular selling size plus other manufacturers are offering different models with higher spec'd Tx.
However, why be restricted to only 1000 feet? as:
SLT: Protocol being open, any manufacturer can offer models compatible with it. - models include Receivers &existing Tx with greater range
"SLT: Compatible with any TX-R model made by G.P. or any company that utilizes the protocol which we expect to expand significantly.
Hitec will not offer a stand alone SLT RX but future BnF "Hitec" branded models
(Many more planned) will utilize it thus keeping the cost down. - Mike Mayberry, Hitec/MPX USA"
Alan T.
My Feedback: (325)
RE: Tactic TTX 650
It sounds like we agree that Tactic spec's 1000 ft for the anylink module. This is good reason to use the new Tactic TX (or any Tactic TX for that matter)
RE: Tactic TTX 650
To avoid confusion, only a Tactic SLT transmitter or a Tactic AnyLink module can communicate with a Tactic SLT receiver. The Tactic AnyLink module will work with quite a number of different transmitters, but you still need the module if you wish to use a non-Tactic transmitter to control your model with a Tactic SLT receiver.
RE: Tactic TTX 650
ORIGINAL: Bax
RE: Tactic TTX 650
As of today, Tactic does not offer any receiver that it advertises as full range. Until they release such a receiver, you won't be able to safely use Tactic SLT or AnyLink for larger aircraft.
RE: Tactic TTX 650
ORIGINAL: bigedmustafa
RS
My Feedback: (325)
RE: Tactic TTX 650
I thought all of the full size RX were "full range" This should be at least the TR424 and TR624 and quite possibly the TR324. I see however that the 424 is now a different RX than it used to be. Perhaps it is only the TR624 , it's cheaper anyways an that's what comes in all the flyzone planes.
RE: Tactic TTX 650
Are you asserting, Bax, that the Aurora 9X will NOT be compatible with Hobbico's TxR line of aircraft in spite of supporting the SLT protocol?
ORIGINAL: Bax
ON, CANADA
RE: Tactic TTX 650
Doug is quite correct, these are fine performing receivers at "full" range when used with a Tactic SLT Transmitter. I use the 424 with the cheap TTX440 Transmitter and regularly speck out large thermal soarers, and at least one reviewer used the 624 Receiver on a Quarter-Scale Cub, with a 28cc Spark Ignition engine, with no problems. Only the Anylink seems to be at all limited in range; even then, I think Tactic are being extremely conservative.
http://www.rcuniverse.com/magazine/a...rticle_id=1347
MD
RE: Tactic TTX 650
The TTX 650:
Maximum peak output power at antenna input terminal: 74.47(mW)
Antenna Gain (typical): 1.2 (dBi)
The problem is that the used "SLT" FHSS protocol uses 15ch only.
My Feedback: (34)
RE: Tactic TTX 650
hello everybody...........whats the history of tactic transmitters? ......who makes them? .........the new 6 channel looks nice. the tactic appeared on the scene with the electrics on tower hobby........are they kin to futaba ?...........pault
RE: Tactic TTX 650
ORIGINAL: pault
RE: Tactic TTX 650
I have a tactic 400 and a tactic 600 ,they both are great I have had no issues with them I have 8 planes that I fly weekly ,also I have a tactic 650 that will be deliverde tomorrow . If you need a good get one of these. Scott
My Feedback: (7)
RE: Tactic TTX 650
At Toledo - Weak Signals - they were selling the 650 transmitter for $125.00. And then you take your receipt over to Hobbico and they give you a free six channel receiver. I bought one.
I have started to go thorough the programming menus and they seem to be well thought out. Tomorrow I'll try the new gear in a plane. Todd
RE: Tactic TTX 650
ORIGINAL: ncsky
Got mine yesteday. Easy programming, and a well written manual. I like the case design wkth the molded hand grips.
Mine came yesterday also. I've only had time to barely scratch the surface but I think it'll do. The gimbals are extremely smooth, very good feel.
I think I can figure it out, but it would've been nice if specific instructions for flaperons had been included, as well as at least one auxiliary channel with proportional control.
So far, however, for the price it seems like a pretty good deal.
TP
KY
RE: Tactic TTX 650
I added some Traction Grip material to the molded grip areas on the transmitter, it gives it a better feel. Plus, now when a tree jumps out in front of me, the transmitter won't slip out of my hands.
RE: Tactic TTX 650
I was considering the Futaba 6J also. The drawback I see with the 6J is that it is FHSS or whatever instead of FAAST like other Futaba's. There are third party recievers for FAAST, but I'm not sure about the FHSS. If only Futaba Rx are available for the J6 it can get expensive. If I knew the Tactic could provide a secure link at almost out-of-sight or 1/2 mile I would be interested.
RS
RS
My Feedback: (7)
RE: Tactic TTX 650
ORIGINAL: ramboy
What does the Tactic TTX 650 offer that the Futaba 6J does not? Both appear to be priced about the same.
For flyers like me the Tactic 650 is the way to go. Todd
