servo
ND
servo
i would like to find out how to figure out how to replace stock servos with aftermarket ones for example i want to change out a traxxas 2055 servo how would i go about looking for the right servo to drop right in with little to no modifications any help would be great
My Feedback: (13)
RE: servo
Find the specs on your servo
(Did that for you)
Modulation: Analog
Torque: 6.0V: 86.0 oz-in (6.19 kg-cm)
Speed: 6.0V: 0.20 sec/60°
Weight: 1.59 oz (45.0 g)
Dimensions: Length:1.60 in (40.6 mm)
Width:0.80 in (20.3 mm)
Height:1.43 in (36.3 mm)
Motor Type: Brushed
Gear Type: Plastic
Look for a replacement with the same rough case size and at least the torque and speed you have, maybe a tad more.
http://www.hitecrcd.com/products/ser...hs-5625mg.html
Hitec HS-5625MG
Motor Type: 3 Pole Ferrite
Bearing Type: Dual Ball Bearing
Speed (4.8V/6.0V): 0.17 / 0.14
Torque oz./in. (4.8V/6.0V): 110 / 131
Torque kg./cm. (4.8V/6.0V): 7.9 / 9.4
Size in Inches: 1.59 x 0.77 x 1.48
Size in Millimeters: 40.39 x 19.56 x 37.59
Weight ounces: 2.11
Weight grams: 59.82
Doesn't mean this would be a good replacement. I would think it would be but there might be better, I didn't spend much time looking. You can also do a RCU search for "traxxas 2055" or "traxxas 2055 replacement" to see what others might have already said.
(Did that for you)
Modulation: Analog
Motor Type: Brushed
Gear Type: Plastic
Hitec HS-5625MG
Weight ounces: 2.11
Weight grams: 59.82
RE: servo
One other thing to watch out for when you change brands of servos. Different brands turn in different directions with the same change in input pulse width so you may have to change the reverse switch in your transmitter to get the same reaction from the new servo.
RE: servo
ORIGINAL: Rodney
