How to set up dual rudder servos, Push-Pull
Reply
Old 09-17-2003, 10:37 PM
Paul Cataldo
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default How to set up dual rudder servos, Push-Pull
Guys,
I will be using two Hitec 5945mg's for my rudder. I am not talking about ganging them together, but rather, I will have one servo on each side of the fuse. In the tail, of course. I am using a Futaba 9C. My main concern is that the Airwild MLP servo arms won't both fit onto the servo shafts at the exact same angle to the servo case, and they might fight each other when I input to the rudder. Do I have to get a hold of a servo programmer? Should I just use a Y harness? Will I still need the servo programmer if I use a Y harness? Thanks.
Paul Cataldo is offline
Old 09-17-2003, 11:49 PM
Flyfalcons
Flyfalcons's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: How to set up dual rudder servos, Push-Pull
You can put them on separate channels and adjust the sub trim and ATV for each servo to match them.
Flyfalcons is offline
