Specktrum switch selection
I have a Spectrum DX7 radio transmitter and a 6010 or 12 2.4 reciever and I want to use the gear switch for a kill switch. Manual says I can use it for a mixing switch but I could'nt find anything about using it for another switch purpose, is there a way to do it,?
RE: Specktrum switch selection
By default, the "gear" switch should work perfectly to operate your ignition kill switch. Just plug the kill switch into CH 5 (gear) on the receiver and check to see if the on/off positions are correct, if not, just go to the servo reverse screen and reverse the "gear" channel as needed. Most optp kill switches should work with the end point adjustments set to the default +100%/-100% settings. The gear switch/channel can be used for any on/off function you want
Pete
Pete
ORIGINAL: pilotpete2
By default, the ''gear'' switch should work perfectly to operate your ignition kill switch. Just plug the kill switch into CH 5 (gear) on the receiver and check to see if the on/off positions are correct, if not, just go to the servo reverse screen and reverse the ''gear'' channel as needed. Most optp kill switches should work with the end point adjustments set to the default +100%/-100% settings. The gear switch/channel can be used for any on/off function you want
Pete
Pete
I'm thankfull for guys like you that help the less knowing, great to have you.
Leroy
Pete I did what you said except I did not have to default the % of current draw. Opto kill switches do not provide any info required to operate them so I have to suspect a signal is all that is required to operate it. At any rate it works fine.
Thanks again, Leroy
Thanks again, Leroy
Pete
Pete
This is exactly how I have used the Gear channel for my opto kill switch.
Paul
