base load antenas
RE: base load antenas
I have used one very satisfactorily on my 8103; they should work every bit as well with the 10X, 'cause the "adapter" and the antenna are the same for either radio. On the other hand, the 10X antenna slips away into the case very nicely.
NY
The only reason you should worry if you're planning on gettinga rubber ducky is if you fly at the extreme end of the range of your existing whip antenna. If you're a 'normal' flyer you shouldn't have problems with it.
