Is there a need for dual Rcvr with 2.4 System?
PA
Hello Guys, I am about to embark on a large build of a Super Flyin King. I am reading through the manual and other places to see that originally many guys put in dual Receivers and batteries. Is this a real issue today?
I've been in the hobby for over 30 years, building and flying... and have never felt the need for dual system.
What are the PRO's and CON's of this?
This may have been a topic before, but I missed it.
PA
RE: Is there a need for dual Rcvr with 2.4 System?
Hi Warbird. I get that part. But I wonder how does that work with Binding 2 receivers to a Futaba?
BTW... I have never had a receiver fail me. I have had a servo quit, but that was the result o using a servo without checking it fully after a previous crash.
I know that receivers get blamed A LOT by the guy walking out to the pile of balsa that use to be his plane! LOL But in reality it is 90% of the time the result of "DUMB THUMB" error.
Moderator
hey Red, one thing to keep in mind RE multiple receivers: make SURE the receivers you use support pre-selected fail-safe position on all channels.
(I know a lot of the futaba receivers with 7 or fewer channels only support preselected fail safe position for the throttle... the other channels failsafe to their 'last position')
assume you have one receiver handling the left aileron and left elevator, a second receiver handling the right aileron and right elevator.
if one receiver should lose signal with the ailerons or elevator (or both) deflected, those surfaces would HOLD their positions until the signal is re-gained.
if you had preselected fail safe positions, you could set them to a neutral fail safe position which would allow you to (hopefully) land safely with the remaining aileron and elevator.
Hope that helps!!
Hope that helps!!
Understanding the binding process is key.
You're teaching the reciever to listen to packets that contain the GUID (Globally Unique ID) of the transmitter. (in the case of specktrum it uses the model number as part of the GUID hence model match)
Knowing that you can see how muliple recievers can be bound to a single transmitter but you can't bind multiple transmitters to one reciever.
PA
Jim, Thanks for the info on FAIL SAFE. I had not thought of that possible glitch! I will have to think of that should I go "redundant".
ORIGINAL: Red_Jeepster
1. Redundancy
2. Better servo power distribution
The Con(S):
1. Cost of a second RX. Probably a small fraction of the value of the airplane.
