Spektrum Telemetry Playback
My Feedback: (26)
IL
Does anyone know if you can play back Spektrum telemetry on a PC? is there HH software to download to see what you can record on your SD card?
thanks!
thanks!
RE: Spektrum Telemetry Playback
My Feedback: (26)
IL
thanks Andy!
i'll try running it tomorrow-i saved some data and dont know if there is anything there. if i get stuck, can i send a file to you to see if you can view it?
thanks
Joe
thanks
Joe
My Feedback: (26)
IL
Roger that.
i see some data but i dont understand why the spektrum TX didnt record more info.
how big of a SD do you normally use for a flight?
i am running the GPS, G-force and JetCat modules. i had the original 1GB SD that came with the DX18-QQ
thanks for your help.
CA
Is all the data you are expecting being displayed on the Tx screen? Each parameter must be selected in the Telemetry menu to be processed into the data stream going into the card. 1gig is more than a big enough card. A jet flight probably isnt more than 500k. Even a file with multiple flights is getting fairly large at 1mb .
If you can .zip the file and attach it here Ill have a look and see.
My Feedback: (26)
IL
here you go
its only a few seconds of data.
talke a look at the EGT on the motor-its absurdly high. also on one of the mini files the fades on one channel (L) of the RX is a number that looks more like a SW register/stack number (11520) than the acutal number of fades on one RX.
i appreciate your interest in taking a look at this.
thanks!
hmmm... just tried to upload it and it wouldnt take. i'll try emailing direct
thanks!
ORIGINAL: JoeEagle
Roger that.
Roger that.
1) The switch to turn on logging was not set "correctly" for your flight. If you are using the throttle, make sure you don't throttle below that position while you're flying. Using the gear as a switch makes sense - you have logging all the while the gear is up, but once you drop them it stops. You'll be landing soon anyway.
2) The telemetry antenna is not positioned well to "see" the transmitter
3) You were flying farther away than the telemetry would work well. (Telemetry range is significantly less than control range).
RCGroups allows posting of TLM and SPM files, but RCU isn't there yet.
Andy
CA
ORIGINAL: JoeEagle
here you go
thanks!
here you go
thanks!
My Feedback: (26)
IL
Andy
i had the telemetry record set to the "I" switch on my DX18-which is also the timer.
we were looking at the telemetry while on the ground (timer still on) and we were seeing it on the screen but it was not recorded.
does anyone know why the Spektrum doesnt use a current date when saving a file? when i save a model or this telemetry file, it is always the same date in 2010. what's up with that?? seems weird and certainly not very helpful for Configuration Management.
i'll try a dry run in the shop tomorrow and see what i see
ORIGINAL: JoeEagle
Andy
i had the telemetry record set to the ''I'' switch on my DX18-which is also the timer.
Andy
The timestamp that is used tells radio type and AirWare code version, which can help us with bug fixes.
Andy
My Feedback: (26)
IL
ahhh....the "I" button thing makes total sense now...don't know why i didnt think of that!
will try it tomorrow when we go flying.
Thanks Andy.
Thanks Andy.
