What Kind of Receiver is this?
MN
What Kind of Receiver is this? Is it Aircraft? What channel is it on? ---> On the back of the Dual Conversion FM7channel receiver there are two numbers one is- FP-R127DF, This one is under the name FUTABA Then running down the side there is B1234567 I assume these are the channels. On the back there is a circle that has 20KHz 1991 narrow band . Under that there is FCC ID:AZP4VKFP-R127DF72. There is a tiny red and white tag on the side that says RX46.
My Feedback: (8)
It is a Futaba 127 DF Aircraft receiver. Futaba crystals have a red and white tag. Is that what you are seeing? Should be able to pull it out.
