cgy750
My Feedback: (19)
Considering it is a flybarless controller, probably not. The 3 axis controller used with a flybar head would interact causing all sorts of problems. Its easy enough to convert most helis to flybarless using a conversion kit or by modifying the original head then just use the CGY750 as it was designed to work.
FL
