FrSky TFR8SB Faast Receivers and 14mz
My Feedback: (17)
TX
I understand these 8 Channel receivers can be linked together giving you up to 16 channels but have not found where this has be done with a 14mz or the newer Futaba radios.
Would be interesting to get up to 14 channels for about 70 bucks as compared to a 14 channel Futaba receiver at 170 bucks.
Anyone out there done this or played around with it?????
Thanks in advance!
Thanks in advance!
The instruction sheet should show you how to change the 2nd receiver to be channels 9 thru 16.
As far the the transmitter goes, just make sure it's set for Multi Mode modulation, same as you would for the Futaba R6014 receiver.
Good luck,
Pete
Good luck,
Pete
