FS-TH9X Flysky, no throttle
Hi, I just bought a FS-TH9X radio for my E-Razor 450 (Dynam), but i don't have throttle response, seems that the channel works because i conected another servo in and respond at the stick movement. Some others radios have a security procedure to avoid the motor start when you turn on the radio, does anybody know if this one has it?.
9X radio for my E-Razor 450 (Dynam), but i don't have throttle response, seems that the channel works because i connected another servo in and respond at the stick movement.
. EPA, ATV, Dual & Triple Rates, Expo Differences & Caution includes ESC / BEC Set Up.
and this post may also assist:
. Electronic Speed Control - Why BEC and LVC cause most EP RX problems, posts #2 & #3.
Much more information available under sub section:
"ESC & BEC - Setup to prevent majority of all RF Problems, Brownouts & Crashes"
below
"Radio Systems, Accessories, Alterations and FAQ" at
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
