hitec HS525BB servos-won't respond
My Feedback: (212)
NC
Bought a 60 size ultra stik with these servos in it. The gentleman that I bought the plane from was an airtronics guy and thats the only radio brand he used. When I put my futaba equipment in and plugged the servos in there was no response at all.I plugged in some futaba servos to the same receiver and they worked fine. Am I missing something here? Thanks for the help.
A common trap is that the Futaba plugs have a key so slot one way only into the receiver whereas Hitec plugs can
slot either way into a Futaba receiver. Check that the Hitec signal lead (yellow) is same way around as the Futaba
white lead. If plugged wrong way, the Hitec will not work but no damage is done.
. Servo - Wiring Diagrams = use with other brand RX.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
GA
It could be you just have them plug in wrong ...............but if its an old receiver airtronics before the Non-Z connector you will have to change out the pins......not hard just take your time if its you first time working with the pins. Hear is a good article on the differences and how to do the pins. Good luck
http://www.fatlion.com/sailplanes/servos.html
My Feedback: (212)
NC
Thanks for the help guys. I was able to change out the old non-z connectors and all servos are working with my radio. The how-to article that was posted by checklst was a huge help.I have been in this hobby for 34 years and I don't know how I got along without rc universe and the good people who are found on the site.I love this hobby!!!
GA
Yes this site has saved my bacon more than a few times..............I had that reference book marked for years .........probably came from someone one on this site originally.
I also went to the site that Checklst posted, and after looking around a bit, even though I am not a Glider Pilot, I bookmarked the page, as it as quite a bit of information that is relevant to all forms of RC pilots..
Thank you, Checklst for posting it!
Craig.
Craig.
additional pertinent information.
Just curious, but wonder if there is some reason why the subsequent post 24 hours later gets the accolades?
Much more information available below sub section:
"Glitches & Jitter in Receiver, Servo & ESC - Causes and Cures"
"Servo - Alterations, Calculators, Databases, Leads, Repairs, Convert to an ESC or winch & FAQ."
below
"Radio Systems, Accessories, Alterations and FAQ" at
Alan T.
GA
Sorry AT I missed your links or I would have directed him to your link...............I looked right past your link because I did not see the HTTP//WWW. My mind must be trained to the old looking addresses ............need to slow down the quick thread skimming. I could miss something important........No disrespect intended.
