Futba 12FG - triple rate setup help
Guys, the Futaba manual and FAQs are not very clear on this subject. Has anyone deciphered the code and might be willing to describe the set up procedure ...
With elevator as an example, to get triple rates, you first set up the model so that your normal control stick movement gives you the maximum travel on the control surface. Then, go into the Dual Rate section of the Model Menu. Turn on D/R 1, set the function to elevator, select the desired switch, and have the switch set to OFF/ON/OFF. Now turn on D/R 2, set it to elevator, and set the switch to OFF/OFF/ON.
Now, go into the AFR section of the Model Menu. The curve shown will be for each rate as you flip the switch. With the switch set in the original position, your curve should be set for the normal operation. Move the switch to the middle position and adjust the rates as you desire for the first lowered rate. Now move the switch to the third position and do the same for your second lowered rate. You're Done! You now have three rates: Normal, #1, and #2.
