switch harness and wire length
Reply
Old 05-09-2014, 06:32 PM
roydefiant
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default switch harness and wire length
In order to balance a new jet the A123 batteries must be in fuse but heavy duty switch harnesses (18 gauge wire) are 4 feet away in nose hatch. I will be running 16 gauge wire from batteries 4 feet up to switch and then 4 feet back to power expander/receiver in fuse. The same will be true for lipo battery for turbine ECU. My nephew who is an electrical engineer tells me there should not be a problem with any significant voltage drop as long as everything is heavy gauge wire. Anyone with experience with this type of setup?
roydefiant is offline
Old 05-10-2014, 04:33 AM
dirtybird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I dont fly jets but I I have a toaster that runs off 40 ft of #16 wire. It pulls about 10 amps.
dirtybird is offline
Old 05-10-2014, 05:42 AM
sidgates
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would move the switch if possible.
sidgates is offline
Old 05-10-2014, 09:15 AM
fizzwater2
My Feedback: (60)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
long wires on the power input to an ECU can lead to excessive ripple voltage at the input, damage to the input caps. Too much inductance, the pulsed current driving the motor leads to the ripple. You'd be better off extending the wires from the motor to the ECU and moving the ECU closer to the battery. Either that, or add extra capacitance to the input of the speed control. Dig around in the high performance electric plane forum for more info.
fizzwater2 is offline
Old 05-10-2014, 10:10 AM
dirtybird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
He said a jet. I dont think it uses an ESC
Ata current of 5A the voltage loss of 8ft will be 0.8v
The free air max current is 22 amps but in a bundle its 3.7A
Dont put it in a tube
Old 05-10-2014, 10:55 AM
fizzwater2
My Feedback: (60)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Right you are.. my fault. Thanks for the heads up!
Contact Us Archive Advertising Cookie Policy
