Hitec Flash 5 throttle trim not working.
IN
At first my throttle was not working ,but the throttle trim was working. I fixed the throttle by cleaning the pot with electronic cleaner and it worked. Now the throttle trim is not working-no beep when pushing on the throttle trim-Flash 5 has electronic throttle. Did not see any broken wires. Sprayed trim lever contacts with
electronics cleaner ,but it still does not work.
Did not see any broken wires. Sprayed trim lever contacts with electronics cleaner ,but it still does not work.
Reassemble making sure rocker is making correct contact.
Otherwise refer to:
. Hitec Warranty & Service - homepage.
Note: Hitec USA only services North/South America and Canada.
"Hitec USA customer service department is available Monday through Friday*
from 7am- 4:30 pm Pacific time. Reach us at 858.748.8440 or
[email protected] any time you have a question"
• If you are from a country that is outside North and South America, please contact the
Hitec distributor in your country for service.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
IN
Got the throttle trim working. Adjusted the throttle pot shaft and got more servo movement at the low end of the throttle. This allowed the throttle trim to work at the lower end of the throttle .
Alan T-thanks for your help. You web site is a real help for all kinds of repairs.
