battery in a channel
WA
Hi-------- I read in a group somwhere that you can pulg a extra battery into any unused channel on your receiver and use it as to power ----something!!-- I feel it is is as a receiver battery- you can't attach a elecrtifly battery pac for the motor this way can you?
Rone
done the best I could
Rone
NY
RE: battery in a channel
Make sure the packs are matched (both capacity and voltage) or you may have problems but yes you can plug a battery into any unused slot (or into any used slot with a Y connector)
