Spektrum DX 7 Programming
I have used the Spektrum DX 7 but don't understand how to efficiently program the radio. I typically use a 6 channel receiver utilizing one servo for each aileron and one for rudder, one for elevator. How do I set up the individual channels? Mix 1, 2, 3, 4, etc. Thank you.
Select the Flaperon wing type.
Done!
THRO will be your throttle.
AILE will be your right aileron.
ELEV will be your elevator.
RUDD will be your rudder.
GEAR will be your gear switch.
AUX1 will be your left aileron.
AUX2 will be your Aux2 switch.
There is no need to use mixes. The radio does this automatically for you using the wing type.
Andy
Done!
Andy
