DX18 Gear Door Question
PA
I am currently working on the Hangar 9 60 CC Corsair. I am using Robart pneumatic retracts and servo operated retract doors. Each door has its own servo. Is there a way with the DX18 to individually control each of the 4 servos (meaning reverse, end point adjustment, etc)? I will be using the receiver extender to give me the additional 8 channels and, or course, can plug each servo into individual channels, but, is there going to be a way to mix everything together along with the pneumatic switch and sequencer? I relatively new to the DX18. Thanks for any help.
You can only use 1 sequencer, the pneumatic one or the transmitter one. What is "pneumatic switch" you refer to, is that the valve that controls the individual retracts?
I'm pretty sure you can do this with the DX18, but I need more info on how you want things to operate. FWIW, the radio comes with two pre-defined sequencers. Sequencer 1 is P-51-style doors that open for the gear to go down, and then close, and Sequencer 2 is for one that the doors stay open (like a Corsair).
Andy
Andy
